Can I/NET Software be translated into another language besides English?
  • Can I/NET Software be translated into another language besides English?
  • Chris_Asbury
    Chris_Asbury
  • sesa139513
    sesa139513
‎2018-09-07 12:16 PM
Last Updated: Administrator DavidFisher Administrator ‎2020-08-11 10:10 AM
Can I configure (translate) the I/NET Software into another language besides English?
Is I/NET supported in different languages?
I/NET Seven ver 2.41 supporting the user interface for either Chinese Language (Traditional) and Chinese Language (Simplify).
TAC INET
  • I/NET 2000
  • I/NET Seven
I/NET is provided in U.S. English language. Translation into other languages is possible with some limitations.
There has been some success observed in translations using a product called Passolo. Although Passolo is not supported by Schneider Electric, you may employ it as a translation tool at your own discretion. More information is available at SDL/Passolo. Note: Passolo does not modify Windows® dialog boxes - this is managed by the language used during installation of the Operating System.
This Customer Advisory CA-2001-09 - Update INET2000 and Languages.pdf discusses various items on this issue. Customer Advisory 2001-09 dated 10/1/2001.
Within the I/NET Seven CD there is a folder called Inet7-Translation which contains the relevant file used with any translation software.
Update from 2011: for I/NET Seven Ver 2.41 and its support of the user interface for either Chinese Language (Traditional) and Chinese Language (Simplify). Answer: If you are talking about translating language then, yes, it should be translatable through the 3rd party translation program. Although we do not test translation in the lab.
Update 2013: There are freelancers who could be of assistance to help your site. https://www.upwork.com site with potential low cost translators.
  • TAC INET
  • 939
