Can I/NET 2000 translate key/card numbers greater than 24000 without using "the Key/Card Translation Table?
  • Can I/NET 2000 translate key/card numbers greater than 24000 without using "the Key/Card Translation Table?
‎2018-09-06 11:57 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:34 AM
Can I/NET 2000 translate key/card numbers greater than 24000 without using “the Key/Card Translation Table?
I/NET Site
I/NET 2000 revision 2.x can translate “large” key/card numbers. However, this feature requires that the SLI and DPU firmware loads are compatible. Refer to TCON 237 for more details.
  • TAC INET
  • 1325
