Can Cat 6 cable be used with continuum network controllers?
  • Can Cat 6 cable be used with continuum network controllers?
  • sesa116827
    sesa116827
‎2018-09-06 11:10 AM
Network Question
Continuum 1.XX
All controllers
Ethernet Cable question.
Not only is Category 6 cable future-safe, it is also backward-compatible with any ... What is the difference between a CAT5 and CAT6 patch cable?
Cat 6 will be overkill but will work fine. It has more stringent specs for crosstalk and noise than 5e and is designed to support 10GBASE-T.
  • 11016
