Camera events triggering an output
  • Camera events triggering an output
  • AdamSteele
    AdamSteele
Guinan AdamSteele Guinan
‎2022-11-03 12:17 AM
on ‎2022-11-03 12:17 AM
Setting up camera motion detected or camera image lost camera events to trigger an Output or Output Group.
EcoStruxure Security Expert
  • Security Expert
  • Video Integration
Through various Video Integrations, Security Expert is able to use camera events (such as camera motion detected) to popup a camera window when those events are seen. However, camera events are not associated with an Input or Door and therefore Security Expert is not able to trigger Outputs or Output Groups directly from these camera events.
Camera events are not able to be used to trigger Outputs or Output Groups in Security Expert.
If this is a requirement, contact local solution category management to have this setup as a new feature.
  • EcoStruxure Security Expert
Tags (2)
  • AdamSteele22
  • AdamSteele24
