Calectro / Schneider Electric smoke detector venturi pipe
  • Calectro / Schneider Electric smoke detector venturi pipe
  • SESA150559
    SESA150559
‎2018-09-06 10:42 AM
When ordering the UG-3-A40, which venturi pipe is included?
UG-3-A40 Smoke detector
UG-3-A4I Smoke detector
Venturi pipes:
VR-0.6M
VR-1.5M
VR-2.8M
Depending on application, different length venturi pipes may be required
The 0.6M is included in the UG-3-A40 and UG-3-A4I package.
Other lengths available are 1.5 and 2.8m lengths but needs to be ordered separately.
  • Field Devices
  • 12322
100% helpful (1/1)
