Calectro / Schneider Electric cross reference
  • Calectro / Schneider Electric cross reference
  • SESA150559
    SESA150559
‎2018-09-06 10:43 AM
Parts of the Calectro product range can be ordered through Schneider Electric as Class 3 products.
Part number Description
6553066000 VR-2.8M
6553065000 VR-1.5M
6553049000 UG-mounting bracket
6553048000 STB-4-SE base f.smokedet.f.cei
6553047000 NSAOS/i smoke detector
6553046000 NSAIS/i smoke detector
6553039000 Smoke Sensor UG-Cover
6553036000 Smoke detector UG-3-A5O
6553038000 Smoke detector UG-3-O-F
6553037000 Smoke detector UG-3-J-F
6553035000 Smoke detector UG-3-A51
6553017000 Smoke detector UG-2-NS-AOS
6553016000 Smoke detector UG-2-NS-AIS
6553015000 Smoke detector ST-I-LON
6553014000 Smoke detector ST-P-DA
6553013000 Smoke detector ST-I-DA
6553007000 Control unit ABAV-S3 230v
6553006000 Control unit ABAV-S3 24v
6553033000 Smoke detector UG-3-A4I
6553034000 Smoke detector UG-3-A4O
6553028000 Smoke detector UG-3-O
6553027000 Smoke detector UG-3-J
Cross referencing Calectro and Schneider Electric part numbers
6553066000 VR-2.8M
6553065000 VR-1.5M
  • Field Devices
  • 12298
