CPU light on ACX7xx flash rapidly (at bout twice the normal speed)
  • CPU light on ACX7xx flash rapidly (at bout twice the normal speed)
  • AbeMeran
    AbeMeran
‎2018-09-06 10:24 AM
After an attempt to cold start the controller by removing AC power with the batteries disconnected, the unit started up with its CPU light flashing very rapidly (hard failure mode)
ACX780
ACX781
Partly cleared memory.
The random access memory  (RAM) on the ACX78x take a long time to erase.
Remove the batteries
Power down the unit
Wait 5 minutes
Power up the unit
  • 13255
