CNT block in the Function Block Editor is replaced by the PI block.
  • CNT block in the Function Block Editor is replaced by the PI block.
  • sesa150555
    sesa150555
‎2018-09-06 09:41 AM
  • How to set up a pulse counter input in a function block program
StruxureWare Building Operation Workstation
Function block editor
Differences between the regular Menta and the Builder Function Block editor programming
The CNT block is replaced by the PI (Pulse input) block in the function block editor. In Workstation, connect the PI to a input where the sensor type is set to counter.
  • 15679
