Buttons on an I/STAT or M/STAT are not working on a Xenta 102-AX
  • Buttons on an I/STAT or M/STAT are not working on a Xenta 102-AX
‎2018-09-06 01:41 PM
An I/STAT or M/STAT plugged into a Xenta 102-AX will display the room temperature but it is not possible to enter service mode -- none of the buttons do anything.
  • Xenta 102-AX
  • M/STAT
  • I/STAT
There are different versions of the I/STAT and M/STAT for the Xenta and I/NET product lines.
  • For use with a Xenta 102-AX, use an I/STAT-A or M/STAT-A
  • For use with an I/NET MR-VAV-AX use either an I/STAT or I/STAT-A, or M/STAT or M/STAT-A
  • 5441
