Building Advisor Report (MS Word format), the page formatting is incorrect after saving
  • Building Advisor Report (MS Word format), the page formatting is incorrect after saving
  • DavidChild
    DavidChild
  • Gary
    Gary
Gary Schneider Alumni (Retired)
‎2021-11-04 04:30 AM
Last Updated: Guinan RobertAndriolo Guinan ‎2021-11-04 03:01 PM
When a Building Advisor "value report", "Smart Alarm Report" or "BMS Health Report" are saved, the page formatting can be incorrect.
In this example, when saved, the document shows page 2 as blank, the original contents of page 2 are then split across pages 3 and 4:
EcoStruxure Building Operation, EcoStruxure Building Advisor
Building Advisor
Word document has incorrect formatting when saved due to the header.
Steps to remove the header manually.
  • Enable edit and save.
  • Close the document and reopen.
  • Double click on the white space i.e. the header.
  • Double click on the image on front page.
The white header should no longer be seen.
The document’s incorrect format has now been repaired.
  • Finally, save the document.
Labels (2)
  • EcoStruxure Building Advisor
  • GaryMontague21
