Bluetooth Adapter Does Not Power On
  • Bluetooth Adapter Does Not Power On
  • Katha
    Katha
Lt. Commander Katha Lt. Commander
‎2025-10-06 04:59 PM
on ‎2025-10-06 04:59 PM
The Bluetooth adapter fails to power on when connected to the SmartX Sensor.
  • Building Operation Automation Server
The “Commissioning Tool Enable” property is set to Off, which prevents the Bluetooth adapter from receiving power.
To resolve this issue:
  1. Open WorkStation.
  2. Navigate to the Sensor Bus Settings.
  3. Locate the “Commissioning Tool Enable” property.
  4. Set the property to On.
  5. Save the changes and verify that the Bluetooth adapter powers on.
  • KatharineVasquez25
