Blank page, No ID code or number displayed in login webpage and can not login to Xenta Server
  • Blank page, No ID code or number displayed in login webpage and can not login to Xenta Server
  • sesa64461
    sesa64461
‎2018-09-10 05:00 AM
This issue has symptoms as below:
  • Blank page, No ID code or number displayed in login webpage and can not login to Xenta Server.
  • Can not access Xenta Server via webpage. The following blank page is displayed:
  • Login page is displayed, but project name and ID code or ID number are not:
  • Windows Server Environment
  • TAC Vista 5.1.X
  • Xenta Server Ver 5.1.X
  • Windows Server "Internet Options" Security Settings are not set properly.
  • Need add the Xenta Server IP address into "Trusted Sites" in "Internet Options>>Security>>Trusted Sites".
  • If didn't add the IP address into "Trusted Sites", blank page would display;
  • If just "http://%Xenta Server IP address%" is added into the "Trusted Sites", would get login webpage which didn't include project name and ID code in the login page;
  • Need remove "http://%Xenta Server IP address%" from "Trusted Sites", and add "https://%Xenta Server IP address%" into "Trusted Sites" list;
  • Then could get correct login webpage,
Labels (2)
  • TAC INET
  • 6637
