Bitwise operations in script is not consistent regarding negative values
  • Bitwise operations in script is not consistent regarding negative values
  • RandyDavis
    RandyDavis
  • MikaelKrantz
    MikaelKrantz
Guinan MikaelKrantz Guinan
‎2021-02-01 11:44 AM
on ‎2021-02-01 11:44 AM
Bitwise operations in script behave differently in the AS-P compare to ES regarding negative values.
  • Building Operation Workstation
  • Building Operation Automation Server Premium
Bitwise operations in the script only defined for positive Integers.
Enterprise Server processes negative operands as twos complement whereas Automation Server Premium does not handle negative operands. Behavior with negative integers is undefined.
  • MikaelKrantz21
