Bit Count not Supported errors in the Active Event view and Event log
  • Bit Count not Supported errors in the Active Event view and Event log
  • ScottLeedberg
    ScottLeedberg
‎2018-09-06 03:02 PM
  • Active Event view
  • Event log
Custom cards will be required if bit count is not supported.
  1. On the door configuration screens make sure the correct card type is selected. (Note: On the door you can select multiple card types).
  2. If the card bit count and/or format is not one that is supported natively by the door then it may be necessary to configure a custom card.
  • 2340
