Battery connector for the SP-PSU-4A power supply
  • Battery connector for the SP-PSU-4A power supply
Guinan AdamSteele Guinan
‎2023-11-02 09:42 PM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:32 AM
Making up battery cables and need to know the part number of the 2-pin battery connector.
2-pin battery connector2-pin battery connector2-pin battery connector
EcoStruxure Security Expert
  • Security Expert
  • SP-PSU-4A
  • SP-PSU-8A
Warning
Hazard of Electric Shock: Remove all power from all devices before removing any covers or doors of the system. Disconnect power at the device and at the power source.
Electrostatic Discharge Required: Always discharge static electricity from your person by touching metal prior to handling any hardware. Failure to do so may result in damage to devices.
Parts not listed in documentation.
The part number for the 2 pin connector is:
  • 2114H-02
The part numbers that make up each of the battery cable types are:
  • CABLE-BATT-SINGLE
    • 2114H-02 x 1
    • 2114T x 2
    • D70400BS-2 x 2
  • CABLE-BATT-DUAL (This is an extender for the single cable)
    • D70400BS-2 x 2
    • A27740CT-ND x 2
  • EcoStruxure Security Expert
Tags (2)
  • AdamSteele23
  • AdamSteele24
