Brand Logo
  • Get started
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      APC UPS, Critical Power, Cooling and Racks
      EcoStruxure IT
      • EcoStruxure IT forum
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • Alliance System Integrators Forum
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • EcoStruxure Automation Expert / IEC 61499 Forum
      • Fabrika ve Makina Otomasyonu Çözümleri
      • Harmony Control Customization Forum
      • Industrial Edge Computing Forum
      • Korea Industrial Automation Forum
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Eldistribution & Fastighetsautomation
      • Elektrik Tasarım Dağıtım ve Uygulama Çözümleri
      • Paneelbouw & Energie Distributie
      • Power Distribution and Digital
      • Solutions for Motor Management
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      • Power Monitoring and Energy Automation NAM
      Power Distribution Software
      • EcoStruxure Power Design Forum
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      • Solutions for your Business Forum
      Support
    • Geo SCADA Knowledge Base
    • Industrial Automation How-to videos
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      • EcoStruxure Building Advisor Ideas
      Remote Operations
      • EcoStruxure Geo SCADA Expert Ideas
      • Remote Operations Devices Ideas
      • Modicon Ideas & new features
    • By Topic
    • By Topic
      • Backstage Access Resources
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
Basic Elevator Control using Credential Types
Access this self-service resource 24/7 and post your questions or scroll through forums for answers on building automation.
  • Communities
  • Basic Elevator Control using Credential Types
  • Article History
Send a co-worker an invite to the Exchange portal.Just enter their email address and we’ll connect them to register. After joining, they will belong to the same company.
  • AdamSteele
    AdamSteele
  • Article History
Share
Janeway AdamSteele Janeway
4 weeks ago
4 weeks ago
When configuring Basic Elevator Control there is no option in the Elevator car for the Credential Type for the Elevator car to use.
EcoStruxure Security Expert
  • Security Expert
  • SP-C, SP-RDM2, SP-I16, SP-O8, SP-IO84
The AN 248 Security Expert - Configuring Basic Elevator Control - Integration Guide does not describe how to handle credential types as the Authentication mode when configuring Elevator cars.
For card formats other than the default selection in the Door record, Credential Types are used with Door Types to define the credential to be used to authenticate at that door. When configuring Elevator control however, the Elevator car record does not have a Door Type field to set the relevant Credential Type to use.
  1. In the Elevator Car record set the Authentication mode field to "<not set>". This will process as normal if the user has a valid credential based on the Reader Expander Reader Port configuration.
  2. The Reader Expander Port is set to "Custom Credential" and "Elevator" for access.
  3. The Elevator car reader will go through the list of Credential Types programmed in the controller and match the Bit Stream of the card read to the first Credential Type that fits.
    1. If there were three Credential Types programmed as below;
      1. 32 Bit
      2. 37 Bit
      3. 26 Bit
    2. Badging a 26 bit card would use the first 26 bit format found in the list which would be Credential Type number three.
  4. Typically this would work fine in most cases however some additional allowances will need to be made if there are multiple credentials with the same number of bits.
    1. If there were multiple 32 bit formats;
      1. ESMI 32 Bit
      2. Custom 32 Bit For Elevators
    2. The system will use the first matching format which would be the ESMI 32 bit, this would result in your elevator processing the wrong format and therefore potentially not granting access.
    3. To resolve this the Credential Types would need to be programmed so that the first credential is the one the elevator needs to use.
      1. Custom 32 Bit For Elevators
      2. ESMI 32 Bit
  • EcoStruxure Security Expert
  • AdamSteele23
Share
You can subscribe to this forum after you log in or create your free account.
Already have an account?Login
Terms & Conditions Privacy Notice Change your Cookie Settings © 2023 Schneider Electric, Inc
