BCX 9640 not able to communicate Bacnet MSTP on Comm1
  • BCX 9640 not able to communicate Bacnet MSTP on Comm1
  • Carl_Slack
    Carl_Slack
‎2018-09-06 01:56 PM
Is there an Xdriver for the purpose of using comm1 as an BACnet over
MSTP for this netcontroller BCX 9640 and still use comm2 as
Infinet?
BCX 4040
BCX 9640
Supported feature to use Bacnet MSTP on a BCX 9640 on Comm1 via x-driver
There is no x-driver to allow MSTP Bacnet communications on a BCX 9640
NOTE: Suggestion would be to use a BCX 4040 and Comm2 for MSTP Bacnet Communications.
  • 4964
