B-tree and rebuild can not fix a problem in an access control file
  • B-tree and rebuild can not fix a problem in an access control file
‎2018-09-06 03:30 PM
I/NET Access Control
You must first use the AC file conversion utility to convert it to a MDB format.
  1. Select mdb as the target file type
  2. Open the file in Microsoft Access
  3. Delete the problem records
  4. Run the AC file conversion to reconvert it back to AC file type
  5. Run the conversion from 1.XX to 2.XX.
  • TAC INET
  • 942
