B-Link Repeater with EcoStruxure Building Operation
  • B-Link Repeater with EcoStruxure Building Operation
‎2018-09-06 01:48 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:33 AM
Can B-Link repeaters be used with EcoStruxure Building Operation?
EcoStruxure Building Operation site release 1.xxx and higher
Need to add repeater(s) for EcoStruxure Building Operation
For communication using RS-485, the versions of B-Link BACnet MS/TP Repeaters repeaters shown below were tested and passed for EcoStruxure Building Operation use.
Part Number Description
B-LINK-AC BACnet MS/TP Repeater, 120/240VAC
B-LINK-AC-OP BACnet MS/TP Repeater, 120/240VAC, open class no enclosure
B-LINK-AC-S B-LINK, AC, SMK
B-LINK-DC BACnet MS/TP Repeater, 24VDC
B-LINK-DC-OP BACnet MS/TP Repeater, 24VDC, open class no enclosure
B-LINK-DC-S B-LINK, DC, SMK
B-LINK-F-AC B-LINK, AC, FIBER
B-LINK-F-AC-S B-LINK, AC, FIBER, SMK
B-LINK-F-DC B-LINK, DC, FIBER
B-LINK-F-DC-S B-LINK, DC, FIBER, SMK
Note the supported cable diameter in microns: 62.5/125. The first number, 62.5, refers to the diameter of the fiber cable's core. The second number, 125, refers to the diameter of the outside of the fiber cable's cladding.
For more information see:
  • BACnet b-Link MS-TP Repeaters - Andover Continuum - Specification Sheet
  • b-Link Series - Andover Continuum - Installation Sheet
  • Additional information about Fiber diameters from The Fiber Optic Association
  • Fiber cabling information for an Infilink i2210 and the B-link-F Series
  • 5207
100% helpful (2/2)
