Automatic login into a Continuum system
  • Automatic login into a Continuum system
  • sesa116871
    sesa116871
‎2018-09-06 01:34 PM
When a user logs off a Continuum workstation, they would like the workstation to login itself maybe via a program as a Guest so that the systems can be viewed (Guest Mode).
Continuum Cyberstation and webClient (all versions)
Continuum is a security system, and as such, it requires a login for auditing purposes.
There are no supported applications or features to provide auto-logins to Continuum.  Continuum is a security system, and as such, it requires a login for auditing purposes.
  • 5654
