Auto Generated Reports not running in 64-bit Environment
  • Auto Generated Reports not running in 64-bit Environment
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-11 12:54 AM
I/NET 2.43 64-bit
I/NET 2.42 64-bit
Issue with windows scheduler is causing Auto Generate reports to fail.
  1. Modify existing or newly created auto generate reports.
  2. Click on the Recurrence button
  3. On the "Task" Tab, modify the "Run" string.
  4. At end of the string you will notice sch=<ScheduleName>. Add the characters"/T0" or "-T0" as shown below
Before:
After:
  • TAC INET
  • 12684
