Attribute does not exist when importing personnel object.
  • Attribute does not exist when importing personnel object.
  • AbeMeran
    AbeMeran
‎2018-09-06 12:21 PM
Importing personnel object gives attribute name error.
CyberStation
Info1 - Info6 attributes were renamed, the export file contains the new attribute names.
During the import process the system expects the original attribute names.
Edit the export file and change names back to info1-info6.
  • 7945
