Attempting to start I/A Series G3 Workbench generates the following error - Exception in thread "main" java.lang.NoClassDefFoundError: com/tridium/sys/Nre caused by: ja...
  • Attempting to start I/A Series G3 Workbench generates the following error - Exception in thread "main" java.lang.NoClassDefFo...
  • WaynePeters
    WaynePeters
‎2018-09-06 12:27 PM
Attempting to start I/A Series G3 Workbench generates the following error:
Caused by: java.lang.ClassNotFoundException: com.tridium.sys.Nre
        at java.net.URLClassLoader$1.run(Unknown Source)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.net.URLClassLoader.findClass(Unknown Source)
        at java.lang.ClassLoader.loadClass(Unknown Source)
        at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
        at java.lang.ClassLoader.loadClassInternal(Unknown Source)
I/A Series G3 Workbench (all versions)
The software is unable to locate class files provided within the baja.jar file.  The baja.jar is missing from the Niagara G3 module folder.
Re-install Niagara and verify the path for installation is correct.  If this does not correct the issue, manually copy all files from the I/A Series G3 installation CD module folder into the appropriate modules folder on the target computer.
  • TAC IA Series
  • 7734
