Assigning global or indirect points to an MR
  • Assigning global or indirect points to an MR
  • sesa139513
    sesa139513
‎2018-09-06 03:14 PM
Why not assign global or indirect points to an MR?
I/NET Site
If you do, anytime your sublan has communication problems, they will often cause problems on your controller lan. Another problem is that point values from indirect points to not pass through some MR-DDC modules.
  • TAC INET
  • 1610
