Assigning an Extended Trend Log to a Meter Object
  • Assigning an Extended Trend Log to a Meter Object
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-11 07:32 AM
StruxureWare Building Operation Reports Server
User wishes Meter Logs to show up in Energy Reports
  1. Configure the Extended Trend Log and set "Include in Reports" to True.  Ensure that the Log has correct Units
  2. Create a Meter Object inside the Energy Folder
  3. Change the Meter Trend Log to the appropriate Extended Trend Log.
  • 16527
50% helpful (1/2)
