Are there replacement part numbers for the MNL-V1RV3 and MNL-V2RV3 circuit board and base actuator assembly?
  • Are there replacement part numbers for the MNL-V1RV3 and MNL-V2RV3 circuit board and base actuator assembly?
  • WaynePeters
    WaynePeters
‎2018-09-06 10:50 AM
Replacement of circuit board and / or base actuator assembly required.
MNL-V1RV3 circuit board assembly is MNL-V1RV3-500
MNL-V2RV3 circuit board assembly is MNL-V2RV3-500
Actuator base assembly is MN-FLO-701
  • TAC IA Series
  • 11935
100% helpful (1/1)
