Application Error / Security Exception displayed when trying to display I/A Series R2 or I/A Series G3 graphics.
  • Application Error / Security Exception displayed when trying to display I/A Series R2 or I/A Series G3 graphics.
  • sesa116868
    sesa116868
‎2018-09-11 04:26 AM
A Windows dialog box
pops up when trying to access an I/A Series R2 or I/A Series G3 graphic page indicating that there is a Security Exception -- "Your security settings have blocked an application from running with an insecure or expired JRE."
I/A Series R2
I/A Series G3
Java security warning caused by trying to run a self-signed java applet.
Open the Java Control Panel found in the Windows control panel, click the security tab in the displayed window then change the security setting from High (or Very High) to Medium.  Click [OK] to close the window saving the settings.  This image of the control panel security page shows the security level already set to medium.
  • TAC IA Series
  • 13775
