Anti-virus software detects some TAC Vista files as virus
  • Anti-virus software detects some TAC Vista files as virus
  • HenrikTarpgaard
    HenrikTarpgaard
‎2018-09-06 12:07 PM
Last Updated: Administrator DavidFisher Administrator ‎2019-10-03 07:29 AM
  • TAC.Common.License.Flex.dll and LicenseAdapterDLL.dll are detected as viruses
  • Is there a virus in TAC Vista or the Vista installation files?
TAC Vista
TAC Vista
It is not uncommon that anti-virus software perceives perfectly clean files as viruses. This is a growing problem as the amount of viruses are continuously growing, and the likeliness that they may share similarities in the code with a Vista file thereby increases.
Although there is a small possibility that the Vista files may be infected by an existing virus on the computer, this is most likely a false positive detection by the anti-virus software.
If the anti-virus software detects a virus, check what symptoms that virus have and if you have experienced any of them.
In most anti-virus software there is a setting to exclude certain files or folder from the scan, which could be used as a workaround if you get repeated alerts (given that you have ensured that there is no virus present at the computer)
  • 8354
