Annual drift of sensor value STD500, STR500. 10kOhm NTC type
  • Annual drift of sensor value STD500, STR500. 10kOhm NTC type
  • SESA150559
    SESA150559
‎2018-09-06 11:07 AM
In some cases, the annual drift of sensors are requested.
STR500 004606000
STR502 004606100
STR504 004606200
STD500 5123074010, 5123078010
STD501 5123082010
The annual drift of the sensors is not documented in data sheets or similar.
Unfortunately, this information is not available from the manufacturers of the sensor elements.
  • Field Devices
  • 11163
