All values in the Xenta 102-AX Plug-in are blank
  • All values in the Xenta 102-AX Plug-in are blank
‎2018-09-07 07:38 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-11-19 07:28 AM
All values in the Xenta 102-AX Plug-in are blank.
TAC Vista
  • Xenta 102-AX Plug-In
  • LonMaker
If the Resource File Languages have become corrupted on your PC, then the plug-in will not know how to display the required data. Go to LonMaker > Network Properties > Resource File Languages.
If the only Language listed is "ENU," then the language files are corrupted. ENU is the default language and will display all data in the LNS environment -- plug-ins, browser, get values -- in an enumerated format that is not usable. Everything will continue to work, but monitoring data in the LNS environment and configuring ASCs via plug-ins will be impossible.
Restore the Resource File Languages:
  1. Shut down LonMaker
  2. Go to http://www.lonmark.org/technical_resources/resource_files/
  3. Download LonMarkResourceFiles1300.exe
  4. Run the executable
  5. Restart LonMaker
  6. Check Network Properties again. US English should be listed and the plug-in should populate with data.
Note: There may be Beta versions 13.04 and 13.10 on this website. Do not use these LonMark resource files. The newer versions cause errors in the 102-AX plug-in. For more information see Opening the Xenta 102-AX plug-in results in "request for LonMark Object status" error .
  • 4004
