All Remote Clients share network functions with the server including auto-DCU save.
  • All Remote Clients share network functions with the server including auto-DCU save.
  • sesa139513
    sesa139513
‎2018-09-06 02:47 PM
I/NET site with Filemaster and Remote Clients
Equalization
Not only is the network configuration saved in the SQL database, but also the network functions. That means the server and ALL remote clients will check every controller on every link in the system and save any that have changed beginning at 3:15 AM everyday. If you have many hosts and many controllers, it could create quite a bit of network traffic.
You might consider turning on auto-save on Fridays or once a month or some other strategic interval.
  • TAC INET
Tags (3)
  • 3047
  • File Master
  • Remote Client
