Alarm view is not shown in TAC Vista Webstation
  • Alarm view is not shown in TAC Vista Webstation
  • sesa150555
    sesa150555
‎2018-09-11 02:52 PM
Alarm view is not shown in Webstation instead this or similar is shown:
The following errors have occurred.
Please correct these errors and/or contact the system administrator.
An unexpected exception has occurred:
Index was outside the bounds of the array.
System.IndexOutOfRangeException
at TAC.WebStation.Modules.Alarms.AlarmViewTable.GetColumnData(Object[]
rowData, Int32 columnIndex)
at
TAC.WebStation.Modules.ViewTableBase.AddColumnsToQueryString(QueryString
queryString, Object[] rowData, Int32[] columns)
at
TAC.WebStation.Modules.Alarms.AlarmViewTable.CreatePropertiesCell(Object[]
rowData)
at TAC.WebStation.Modules.Alarms.AlarmViewTable.CreateAlarmRow(Object[]
rowData, Int32 rowIndex, Boolean isDisabledView)
at TAC.WebStation.Modules.Alarms.AlarmViewTable.CreateTable(Table table)
at TAC.WebStation.Modules.ViewTableBase.FillTable(Table otherTable)
at TAC.WebStation.Modules.Alarms.AlarmListPage.DataBind()
at TAC.WebStation.Modules.Alarms.AlarmListPage.Page_Load(Object sender,
EventArgs e)
at System.Web.UI.Control.OnLoad(EventArgs e)
at System.Web.UI.Control.LoadRecursive()
at System.Web.UI.Page.ProcessRequestMain(Boolean
includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
TAC Vista
  • TAC Vista Webstation
  • TAC Vista Server
If "site" is checked in the $alarmcolumns object this happens. This is a known defect.
  1. Find $Alarmcolums in the root folder In workstation
  2. Go to Properties and uncheck the site option
  • 16208
This is a heading
