Alarm message: "Trend Log Object [Object Name]. Could not transfer log values automatically. Try Manually"
  • Alarm message: "Trend Log Object [Object Name]. Could not transfer log values automatically. Try Manually"
  • Sampath_Konda
    Sampath_Konda
‎2018-09-06 01:47 PM
Alarm message received "Trend Log Object [Object Name]. Could not transfer log values automatically. Try Manually"
  • Vista Server
  • Xenta Controllers
  1. Log space set to 0 seconds or minutes for trend log.
  2. Communication breakdown between Vista and Xenta Controllers.
  1. Set Log Space to minimum 10 sec or 1 min per trend log
  2. Communication between Xenta and Vista should be normal.
  • 5257
