Alarm block limitation in a single Menta application
  • Alarm block limitation in a single Menta application
‎2018-09-07 12:55 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-08-20 10:57 AM
Generating a Menta application results in the following error if the maximum number of Menta blocks is exceeded in the application:
TAM32
The maximum number of Alarm blocks is exceeded in the application.
The problem must be solved before the application can be generated.
TAC Vista
  • Menta
  • Xenta programmable controllers
  • Xenta 281, 282, 283, 301, 302, 401, 401:B
Generating a Menta application results in an error if the maximum number of Menta blocks is exceeded in the application.
There can be no more than 127 alarm blocks in a Menta application.
Tags (4)
  • 1190
  • 200
  • 300
  • 400
