After upgrading the XBuilder program, you may get "File not found" error message when generating the project.
  • After upgrading the XBuilder program, you may get "File not found" error message when generating the project.
  • MikaelKrantz
    MikaelKrantz
‎2018-09-07 01:29 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-10-29 07:29 AM
After upgrade of Xbuilder or opening a project built on another computer generating the project causes a "File not found:" error message.
Satchwell MicroNet, TAC INET, TAC Vista
XBuilder
Find the alarm or event page that is causing this problem and view the reference field to identify the cause of the problem.
  • XBuilder was upgraded and the xmle files from the previous version are no longer present.
  • XBuilder installation directory was on a different drive on the computer the project was last used on.
In Xbuilder, right click on all the Alarm and Event pages, select Change reference, and browse in the new path to the referenced file.
Labels (3)
  • Satchwell MicroNet
  • TAC INET
  • 3177
