After installing WorkPlace Tech 5.8 the Hardware wizard cannot be accessed.
  • After installing WorkPlace Tech 5.8 the Hardware wizard cannot be accessed.
  • Kim_Baze
    Kim_Baze
‎2018-09-06 12:44 PM
I/A Series WorkPlace Tech
Earlier versions of WPT 5.7.4, 5.7.5, 5.7.6 and 5.7.7 when uninstalled leave behind files that can cause such an issue.
The simplest solution is to uninstall WPT58 and re-install it.  The uninstall of WPT58 will remove the extraneous files so the next install will function properly.
  • TAC IA Series
Tags (2)
  • 7228
  • scheduler
