After installing Vista 5.1.5, nothing happens when launching Vista server setup or Vista Server. TAC Vista server won't start.
  • After installing Vista 5.1.5, nothing happens when launching Vista server setup or Vista Server. TAC Vista server won't sta...
  • Anonymous user
‎2018-09-07 12:10 PM
After installing Vista 5.1.5 on a new XP or 2003 server PC, nothing happens when launching Vista server setup or Vista Server.
New installation of Vista 5.1.5. New installs only, Vista 5.1.4 upgrades do not apply.
Windows XP and Windows 2003 server.
Windows Imaging Component (WIC) needs to be installed before .NET 4 is installed.
Vista 5.1.5 as a fresh install (not upgraded from 5.1.4) requires Windows Imaging Component (WIC) to be installed before .NET 4(included in Vista installation). This component is also included in Microsoft .Net Framework 3.5.
To resolve this issue, install either Windows Imaging Component or Microsoft.net framework 3.5 (see links below).
Install Windows Imaging Component or...
32-bit: http://go.microsoft.com/fwlink/?LinkId=162643&clcid=0x409
64-bit: http://www.microsoft.com/downloads/en/details.aspx?familyid=f64654ac-6e26-41d9-a90a-0e7783b864ee&dis...
Install Microsoft .net framework 3.5
  1. Visit http://www.microsoft.com/downloads/en/details.aspx?FamilyId=333325fd-ae52-4e35-b531-508d977d32a6&dis...
  2. Download and install Microsoft .Net Framework 3.5
  3. Reboot the computer
  4. Install Vista 5.1.5
  5. If this issue still can't be solved, update to Vista 5.1.6.
  • 4349
