After creating a new station using the "New Station Wizard" in Niagara G3 Workbench, it fails to copy into the ENC using the "Station Copier". This error messag...
  • After creating a new station using the "New Station Wizard" in Niagara G3 Workbench, it fails to copy into the ENC using the ...
  • sesa119747
    sesa119747
  • Kim_Baze
    Kim_Baze
‎2018-09-06 02:36 PM
After creating a new station using the "New Station Wizard" in Niagara G3 Workbench, it fails to copy into the ENC using the "Station Copier". This error message appears:
"The local station database file config.bog is currently in use, and cannot be copied".
It's because a "Save Bog" was not done.
Go back to Workbench and open the station, make a change and do a "Save Bog". The station should now copy without issue.
  • TAC IA Series
  • 3516
