After copying sections of logic from one application to another the ability to connect pointers stopped working.
  • After copying sections of logic from one application to another the ability to connect pointers stopped working.
  • Kim_Baze
    Kim_Baze
‎2018-09-06 10:22 AM
After copying sections of logic from one application to another the pointers from that logic won't connect to other objects and therefore show up as red lines.
WorkPlace Tech
Copying sections of logic from an older application has been known to cause this.
To recover the application remove all objects and reference tags that exhibit the connection issue, compile the application and then re-create the deleted logic by pulling objects from the Shapes window.
  • TAC IA Series
Tags (2)
  • 13377
  • duplicate
