Adjusting a Venturi pipe to the correct size
  • Adjusting a Venturi pipe to the correct size
  • Benji
    Benji
  • MikaelKrantz
    MikaelKrantz
‎2018-09-10 01:49 PM
The calectro smoke detektor has too long pipe to fit
Calectro Smoke detektor
Venturi pipe
The Venturi pipe is long, but also possible to cut
You can cut the Venturi pipe to size but you must only cut it from the end that does not have the sleeve.
See Installation instruction for more information.
  • Field Devices
  • 18608
