Adjust the amount of events sent to Vista using the eventcap command
  • Adjust the amount of events sent to Vista using the eventcap command
  • Sacco
    Sacco
  • sesa150561
    sesa150561
‎2018-09-06 02:32 PM
Vista events from a standalone Xenta 5xx must be adjusted.
TAC Vista
  • Vista
  • Event Logging
  • Xenta 5xx
Situations where the Xenta controller must handle more events while in a "standalone" installation.
In Xenta firmware versions >5.1.3 it is possible to change the event storage capacity of the Xenta with a console command "eventcap".
The variable of eventcap allows the user to define how many event storage files Xenta may have. The valid number range of events is from 10 to 2000. Each file stores ~150 events, depending on event size.
Example: 700 files are recommended to store ~100,000 events.
Note: This only works for Vista events, not I/NET. I/NET uses another memory module of the Xenta device and will not be affected with this change.
Tags (4)
  • 3690
  • 500
  • 511
  • 527
