Adding rows to the device editor in Xbuilder
  • Adding rows to the device editor in Xbuilder
  • Anonymous user
‎2018-09-06 01:34 PM
The Xbuilder device editor by default only allows 200 lines, and some integration efforts require more than 200 points to be programmed.
Xbuilder
Device Editor
The device editor only has 200 rows by default.
The device editor is designed with excel functionality meaning, new rows can be added to allow for more points to be programmed.
To add rows to the device editor follow these steps:
  1. Open the device editor.
  2. Right click on the row number.
  3. Choose insert row.
  4. Type in the desired number of rows (up to 100) If more than 100 are needed repeat steps 2-4.
  • 5631
