Adding nodes to a controller
  • Adding nodes to a controller
  • sesa116834_brid
    sesa116834_brid
‎2018-09-07 02:33 PM
How do I add nodes to my controller?
Netcontroller CX99xx
Netcontroller II
ACX57xx
BCX Series
Adding more nodes to a controller
First you will need to contact upgrades department to obtain a node upgrade flash file for your controller.  Upgrades can be reached at upgrades.continuum@schneider-electric.com
Once you have received your flash file you will being the process of updating your OS.
1.  Rick Click and Edit the controller
2.  Click update OS
3.  Path to file and select file
4.  Verify controller updated
5.  Reload Controller
  • 4945
