Adding a named RI (FBD) does not appear as a Input in AS or ES
  • Adding a named RI (FBD) does not appear as a Input in AS or ES
  • sesa139513
    sesa139513
‎2018-09-06 11:06 AM
Adding a named RI (Function Block Diagram) does not appear as a Input in AS or ES
StruxureWare Building Operation site with AS or ES using Function Block program
Adding a RI (FBD) with the name for example '_PB', it does not appear as a Input in AS or ES
It shouldn't appear as an input on the AS or ES since it is only an input on the Function Block program. You must create the input on the resistive (physical) input on the AS and bind it to the real input on the Function Block.
Function Block is a program running on the AS or ES and only will talk to the outputs when bound to the I/O or Input Output object.
  • 11195
