Adding IO Software Points to an AS-B
  • Adding IO Software Points to an AS-B
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-10 01:52 PM
User unable to find means to add I/O points for an AS-B in workstation
Automation Server Basic
User not selecing the AS-B-XX onboard IO object
  1. In the system tree browse to the IO Bus/AS-B-XX onboard IO
  2. Right click on the object and select New/Input or Output Point
  3. Select the type of IO and continue creating the IO point.
  • 18649
100% helpful (1/1)
