Add-on versions required for use with Continuum 2.0 SP1
  • Add-on versions required for use with Continuum 2.0 SP1
‎2018-09-11 09:08 AM
Last Updated: Crewman ContentModerator ‎2025-10-15 03:37 AM
There are new versions of Continuum Reports, Archiver, Elevator Control, etc. that were updated by the Center of Excellence development team. These applications need to be upgraded prior to using Continuum 2.0 SP1 for sites that use these applications because of new memory mapping.
Windows 7
Windows Server 2008
Continuum
Continuum 2.0 SP1 uses a new memory mapping scheme that allows for better use of large memory addressing. The Continuum Add-on applications needed to be updated in order to work properly, so each of the applications has a new version. Installers need to know which versions to update.
Below is a list of Continuum Add-on applications and versions needed to work properly with Continuum 2.0 SP1.
Prior to installing Continuum 2.0 SP1, you need to upgrade certain Continuum Add-on Applications with new versions.
It is recommended that you be prepared to rollback to Continuum 2.0 should critical applications fail to operate after the upgrade to SP1.
You can download new versions of the following Add-on Applications from The Exchange at this URL: https://www.se.com/myschneider/content/ww/en/gc/general/ecoxpert-landing-page.jsp Search on 'continuumreports' and locate the application.
Add-on Application 2.0 SP1 Compatible Version
Access Groups 2.5.1
BioScrypt 4G V-Station Integration 1.12.1
CFR Extended Log Archiver
CFR Access Event Archiver
CFR Alarm Event Archiver
CFR Activity Event Archiver
Continuum Reports 23.0e
Cogent MiY Integration 1.8.1
DVTel 6.x Video Integration 2.3.2
Elevator Control V2.6.6 2.6.7
EZ-GuardTour 1.2
EZ-Trap 1.9
Genetec Omnicast 4.8 Video Integration 1.1.1
Genetec Security Center 5.2 Video Integration 1.2.1
Personnel Data Importer Continuum Reports 23.0e
Salient Video Integration 1.3.1
Stentofon Integration 1.8
Video Inquire 1.9.1
Customer-Specific Custom Applications
Contact COE.Support@Buildings.Schneider-Electric.com for upgrades for the following customer-specific custom applications:
AckAlarm
Area Templates PIM
CADS
DVTel Alarming
Continuum-Excel
Elevator Control V3.x
Elevator Control V4.x
Elevator - EasyLobby Integration
Extended Log Exporter
PIM 2.0
ScanShell Scanner Interface
Surgard Integration
Vicon Video Integration
xTra
Legacy Applications
Contact COE.Support@Buildings.Schneider-Electric.com for upgrades for the following legacy applications:
Area PIM
Door PIM
Elevator Control V2.4
Elevator Control V2.5
Unlisted Application
Download a pdf copy of this list click the following link:  Continuum Add-On Application version list
Tags (3)
  • 18373
  • excellent
  • suite
