Add entries in the host's routing table
  • Add entries in the host's routing table
‎2018-09-06 03:26 PM
How to add entries in the host’s routing table
Command Prompt
Routing Table Errors
As an example: add the address 157.0.0.0
  1. Go to a DOS screen and type the following:
    Route add 157.0.0.0
  2. Then type:
    Route Print
  3. This address should appear.
  • TAC INET
  • 1110
