Actuator MD20 gearbox materials
  • Actuator MD20 gearbox materials
  • SESA150559
    SESA150559
‎2018-09-06 12:53 PM
Requesting material specifications used in gear box on actuators MD20 in its different versions.
Actuator MD20
Possible exposure to heat (desert climate).
The gear box has a mix of plastic and steel plate gears. 5 in total. Experience from manufacturer states that there should be no issues in using them in a desert climate like Dubai or similar.
  • Field Devices
  • 6948
