Accessing archived data and obtaining reports from archived data
  • Accessing archived data and obtaining reports from archived data
‎2018-09-07 02:18 PM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:08 AM
How to load up archived data in a report using Seven Reports
TAC INET
  • I/NET Seven
  • SevenReports
  • Archiving
Reports show nothing or have one blank page and fail to show data that meets the date window specified
When using Seven Reports to view data, archived data can be viewed and put into a report.
  1. From the Archives pull-down menu, Mount/Dismount the archive files. Files, by default, are stored in the c:\INET Seven Data\Arch folder.
  2. After mounting the needed reports (look at the date of the files in the archive folder), the report used must have the word ARCHIVE in the file name. This specifies that the reports will be pulled not from the current database but rather from the mounted files and on the dates specified.
The reports should now be from the Archived files mounted.
Archive Reports are located on the install CD under CD\Program Files\INET Seven\Reports
To download, click on the link below and select to save the report to your hard disk in the c:\INET Seven Data\Reports folder:
I/NET Seven Release 2.20 and Prior files:
ArchiveOverrideBillingSamples.rpt
ArchiveRuntimeSamples.rpt
ArchiveTransactionsDoors.rpt
ArchiveTransactionsIndividuals.rpt
ArchiveAnalogSamples.rpt
ArchiveConsumptionSamples.rpt
ArchiveDemandSamples.rpt
ArchiveDiscreteSamples.rpt
I/NET Release 2.21 to current:
ArchiveAnalogSamples_xi.rpt
ArchiveConsumptionSamples_xi.rpt
ArchiveDemandSamples_xi.rpt
ArchiveDiscreteSamples_xi.rpt
ArchiveOverrideBillingSamples_xi.rpt
ArchiveRuntimeSamples_xi.rpt
ArchiveTransactionsDoors_xi.rpt
ArchiveTransactionsIndividuals_xi.rpt
Tip:
In some instances, while the report is running and the data is being compiled, if you move the mouse or strike a key, the process starts all over. The solution is to start the report and wait for a few minutes if you have input a broad range of data to search and produce.
  • TAC INET
ArchiveOverrideBillingSamples.zip
ArchiveRuntimeSamples.zip
ArchiveTransactionsDoors.zip
ArchiveTransactionsIndividuals.zip
ArchiveAnalogSamples.zip
ArchiveConsumptionSamples.zip
ArchiveDemandSamples.zip
ArchiveDiscreteSamples.zip
ArchiveAnalogSamples_xi.zip
ArchiveConsumptionSamples_xi.zip
ArchiveDemandSamples_xi.zip
ArchiveDiscreteSamples_xi.zip
ArchiveOverrideBillingSamples_xi.zip
ArchiveRuntimeSamples_xi.zip
ArchiveTransactionsDoors_xi.zip
ArchiveTransactionsIndividuals_xi.zip
Tags (2)
  • 4973
  • RobertAndriolo22
