Access older I/NET 4.xx *.pag files from page markers in new pages made in I/NET 2000
  • Access older I/NET 4.xx *.pag files from page markers in new pages made in I/NET 2000
  • sesa139513
    sesa139513
‎2018-09-07 12:13 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-08-11 08:35 AM
TAC INET
I/NET 2000
Access older files from new pages made in I/NET 2000.
  1. Go to the Graphic Editor, right click on the page-marker, then select Properties.
  2. The next screen is called Graphic Page Marker. In the File Details section check
    • path of the file
    • name of the file
    • extension type
  3. If they are not correct then click on Destination page. Select and then open your file. (You may select *.pag or *.gpg files.) Make sure the correction is now in the File Details then click Okay.
  4. Save the graphic and close Graphic Editor. Test your page marker. Your page should appear.
For conversion up to StruxureWare Building Operation, import the original pag files and convert to gpg. Then using the graphics converter from Building Operation, convert the graphics pages.
  • TAC INET
Tags (2)
  • 902
  • inet
